查看: 2915|回复: 3
[1stopt] 求助有1stopt2.0版以上的好心人,万分万分感谢
发表于 2008-5-4 18:31 | 显示全部楼层 |阅读模式
求助有1stopt2.0版以上的好心人
请帮忙看看编码是否有错
还是因为1.5版无法跑这样的模式阿
网站上找不到2.0版以上的
而软件价格很惊人,无奈实在买不起
拜託有2.0版以上的好心人帮忙跑下面两个的结果
万分万分感谢!!
Title "Type your title here";
Parameters p1[0,1],p2[0,1],p3 [0,1],p4 [0,1],q1 [0,1],q2 [0,1],q3 [0,1],q4 [0,1], m1, m2, m3, m4 ;
Variable t, s1, s2, s3, s4;
conststr   f1=(1-exp(-(p1+q1)*t))/(1+(q1/p1)*exp(-(p1+q1)*t));
conststr   f2=(1-exp(-(p2+q2)*(t-8)))/(1+(q2/p2)*exp(-(p2+q2)*(t-8)));
conststr   f3=(1-exp(-(p3+q3)*(t-20)))/(1+(q3/p3)*exp(-(p3+q3)*(t-20)));
conststr   f4=(1-exp(-(p4+q4)*(t-28)))/(1+(q4/p4)*exp(-(p4+q4)*(t-28)));
conststr   f5=(1-exp(-(p1+q1)*(t-1)))/(1+(q1/p1)*exp(-(p1+q1)*(t-1)));
conststr   f6=(1-exp(-(p2+q2)*(t-9)))/(1+(q2/p2)*exp(-(p2+q2)*(t-9)));
conststr   f7=(1-exp(-(p3+q3)*(t-21)))/(1+(q3/p3)*exp(-(p3+q3)*(t-21)));
conststr   f8=(1-exp(-(p4+q4)*(t-29)))/(1+(q4/p4)*exp(-(p4+q4)*(t-29)));
sharedmodel;
Function
      s1=(f1-f5)*m1*(1-(f2-f6));
      s2=(f2-f6)*(m2+(f1-f5)*m1)*(1-(f3-f7));
      s3=(f3-f7)*(m3+(f2-f6)*(m2+(f1-f5)*m1))*(1-(f4-f8));
      s4=(f4-f8)*(m4+(f3-f7)*(m3+(f2-f6)*(m2+(f1-f5)*m1)));
data;
1    12          0                      0                           0
2    52          0                      0                           0
3    42          0                      0                           0
4    7899      0                      0                           0
5    40844    0                      0                           0
6    63351    0                      0                           0
7    72998    0                      0                           0
8    70181    48                    0                           0
9    75423    587                  0                           0
10   53951   10179              0                           0
11   49001   36363              0                           0
12   47857   35743              0                           0
13   24950   35700              0                           0
14   20905   42342              0                           0
15   25016   56032              0                           0
16   26817   92040              0                           0
17   40527   127376            0                           0
18   18334   138257.5001   0                           0
19   13841   113122.7502   0                           0
20   14009   48757.50015   6907                     0
21   6439     75578.50021   10434.50003        0
22   3300     106116.2503   41947.00013        0
23   4420     88190.75019   51170.00015        0
24   4388     98104.50016   28180.7501          0
25   4203     83067.50016   29325.75014        0
26   4470     84496.50003   49918.25025        0
27   2650     64614              97886.50066        0
28   2100     29939              129780.251          560.250006
29   2300     10657              140870.2511        900.000009
30   1600     23345              133794.0011        7533.000076
31   1300     28162.5           70125.00068        6295.500062
32   1500     28741              98315.00096        38027.25039
33   1725     15815              39736.00037        105129.0011
34   1705     10705              16287.75016        93082.50094
35   2875     11208              9438.750095        110461.5011
36   3100     6354                8923.500089        95294.25096
Parameters p1 [0,1],p2 [0,1],p3 [0,1],p4 [0,1],q1 [0,1],q2 [0,1],q3 [0,1],q4 [0,1], m1, m2, m3, m4, b1, b2;
Variable t, s1, s2, s3, s4, r1, r2, r3, r4, g;
sharedmodel;
Function
      s1=(f1-f5)*exp(-b1*r1)*exp(-b2*g)*m1*(1-(f2-f6)*exp(-b1*r2)*exp(-b2*g));
      s2=(f2-f6)*exp(-b1*r2)*exp(-b2*g)*(m2+(f1-f5)*exp(-b1*r1)*exp(-b2*g)*m1)*(1-(f3-f7)*exp(-b1*r3)*exp(-b2*g));
      s3=(f3-f7)*exp(-b1*r3)*exp(-b2*g)*(m3+(f2-f6)*exp(-b1*r2)*exp(-b2*g)*(m2+(f1-f5)*exp(-b1*r1)*exp(-b2*g)*m1))*(1-(f3-f7)*exp(-b1*r4)*exp(-b2*g));
      s4=(f4-f8)*exp(-b1*r4)*exp(-b2*g)*(m4+(f3-f7)*exp(-b1*r3)*exp(-b2*g)*(m3+(f2-f6)*exp(-b1*r2)*exp(-b2*g)*(m2+(f1-f5)*exp(-b1*r1)*exp(-b2*g))*m1));
data;
1          12              0                       0                      0                    100     0      0      0     0.026
2          52              0                       0                      0                    90      0      0      0     -0.263
3          42              0                       0                      0                    81      0      0      0     -0.029
4          7899          0                       0                      0                    73      0      0      0     0.033
5          40844        0                       0                      0                    66      0      0      0     0.075
6          63351        0                       0                      0                    62.7    0      0      0     0.379
7          72998        0                       0                      0                    59.6    0      0      0     0.144
8          70181        48                     0                      0                    57      57     0      0     0.202
9          75423        587                   0                      0                    54.9    51.3   0      0     0.194
10         53951       10179               0                      0                    53.3    46.2   0      0     0.125
11         49001       36363               0                      0                    52.2    41.4   0      0     0.493
12         47857       35743               0                      0                    51.6    37.2   0      0     0.133
13         24950       35700               0                      0                    51.6    36.5   0      0     -0.27
14         20905       42342               0                      0                    51.6    36.1   0      0     -0.33
15         25016       56032               0                      0                    51.6    35.3   0      0     0.02
16         26817       92040               0                      0                    51.6    35.1   0      0     0.23
17         40527       127376             0                      0                    51.6    35.0   0      0     0.08
18         18334       138257.5001    0                      0                    51.6    34.9   0      0     0.235
19         13841       113122.7502    0                      0                    51.6    34.9   0      0     -0.098
20         14009       48757.50015    6907                0                    51.6    34.9   36     0     0.033
21         6439         75578.50021    10434.50003   0                    51.6    34.9   32.4   0     -0.044
22         3300         106116.2503    41947.00013   0                    51.6    34.9   29.7   0     0.269
23         4420         88190.75019    51170.00015   0                    51.6    34.9   27.2   0     0.099
24         4388         98104.50016    28180.7501     0                    51.6    34.9   25.1   0     0.053
25         4203         83067.50016    29325.75014   0                    51.6    34.9   23.2   0     -0.005
26         447           84496.50003    49918.25025   0                    51.6     34.9   22.6   0       0.128
27         2650         64614               97886.50066   0                    51.6     34.9   22.1   0       0.075
28         2100         29939               129780.251     560.250006   51.6     34.9   21.7   23     -0.084
29         2300         10657               140870.2511   900.000009   51.6     34.9   21.4   20.7  -0.129
30         1600         23345                133794.0011  7533.000076  51.6    34.9   21.2   18.6   0.051
31         1300         28162.5             70125.00068  6295.500062  51.6    34.9   21.1   16.7   0.184
32         1500         28741                98315.00096  38027.25039  51.6    34.9   21.1   15      0.172
33         1725         15815                39736.00037  105129.0011  51.6    34.9   21.1   14.5   -0.048
34         1705         10705                16287.75016  93082.50094  51.6    34.9   21.1   14.2   0.055
35         2875         11208                9438.750095  110461.5011  51.6    34.9   21.1   14.0   0.004
36         3100         6354                  8923.500089  95294.25096  51.6    34.9   21.1   13.9   -0.091
[ 本帖最后由 shearling 于 2008-5-4 18:43 编辑 ]
发表于 2008-5-4 19:49 | 显示全部楼层
你可以找这个帖子里的有关高手帮你解决
http://forum.vibunion.com/forum/viewthread.php?tid=62888&page=1#pid335122
发表于 2008-5-5 11:57 | 显示全部楼层
论坛以解决问题为主,这种代劳...
第一道好办,不用作任何修改;第二道编译不过,说字符串长度大于1024,得琢磨下,用个变通的方式。
第一道结果:
均方差(RMSE): 12162.19152965
残差平方和(SSE): 21300322003.7601
相关系数(R): 0.989539659935644
相关系数之平方(R^2): 0.979188738585551
决定系数(DC): 0.979217329607646
F统计(F-Statistic): 11.9113117844996
参数                  最佳估算
p1                 0.011145488595799
p2                 0.0100096358838427
p3                 0.00413278244235298
p4                 0.00467651326609582
q1                 0.414688897227349
q2                 0.258752699578055
q3                 0.561130139360456
q4                 0.823259672369966
m1                 648654.788181926
m2                 1552278.54918509
m3                 924611.454833871
m4                 544506.533741478
====== 输出结果 =====
文件:Data file - 1
No        实测s1        计算s1        实测s2        计算s2        实测s3        计算s3        实测s4        计算s4
1        12        8876.55521405172        0        2229.57036932295        0        0.0643164473356193        0        3.42812144640003E-7
2        52        13121.4952015355        0        2915.69035619963        0        0.113274958606556        0        7.84556734680223E-7
3        42        19063.7137975061        0        3813.35347220194        0        0.199546650751207        0        1.79552948195978E-6
4        7899        27012.1346496053        0        4987.36976256901        0        0.351628108622712        0        4.10923310761105E-6
5        40844        36947.1796883641        0        6520.15465019531        0        0.619853713840922        0        9.40435704679003E-6
6        63351        48167.9487987436        0        8512.44425819245        0        1.09321914464046        0        2.15227421912897E-5
7        72998        59009.6335401481        0        11079.7750224609        0        1.92925508872717        0        4.92568218787033E-5
8        70181        67013.9944644862        48        14344.2110911955        0        3.40714259839207        0        0.000112729007279128
9        75423        69841.9513355864        587        18425.6020424086        0        6.02227055217275        0        0.000257991789429897
10        53951        66548.6864737075        10179        23439.2534562276        0        10.6548197281782        0        0.000590442615998295
11        49001        58186.7679777674        36363        29498.6157850724        0        18.8708020312557        0        0.0013513018266162
12        47857        47150.9973230131        35743        36707.3628949587        0        33.4600562430897        0        0.00309265954090723
13        24950        35892.5847353519        35700        45124.3258497975        0        59.3967185825466        0        0.00707816865654047
14        20905        26032.2210807773        42342        54700.9641044459        0        105.54783975095        0        0.0162004026669992
15        25016        18220.291815844        56032        65207.2220688602        0        187.693331366729        0        0.0370816785479562
16        26817        12436.4180351277        92040        76169.127357473        0        333.812457161901        0        0.084887529169773
17        40527        8345.97315181488        127376        86845.8504067516        0        593.219704120992        0        0.194365201872053
18        18334        5540.86193070191        138257.5001        96275.5078819433        0        1052.10287998726        0        0.4451963288854
19        13841        3655.74645608231        113122.7502        103407.691902039        0        1859.43697856173        0        1.02037718953499
20        14009        2404.8488198345        48757.50015        107308.801934094        6907        3269.07457517404        0        2.34123636831582
21        6439        1580.69340221045        75578.50021        107383.090396524        10434.50003        5705.21992276996        0        5.38188626274049
22        3300        1039.38836946873        106116.2503        103526.403745219        41947.00013        9855.8536766492        0        12.4094565475772
23        4420        684.014912417219        88190.75019        96148.89357471        51170.00015        16780.4154311604        0        28.7528414375087
24        4388        450.467324546929        98104.50016        86065.7358771657        28180.7501        27955.4031398299        0        67.1026433839
25        4203        296.755136647098        83067.50016        74322.2780144688        29325.75014        45027.5970154852        0        158.092048210617
26        4470        195.463912826525        84496.50003        62041.3615042988        49918.25025        68812.4274611253        0        376.093423509955
27        2650        128.675384675003        64614        50323.8178720934        97886.50066        97154.5763070563        0        898.823953587618
28        2100        84.6390086746993        29939        40119.1154403397        129780.251        122733.629653111        560.250006        2130.06743954274
29        2300        55.6208690470694        10657        31965.4755139584        140870.2511        134661.964620536        900.000009        4914.67217222933
30        1600        36.5166697771486        23345        25766.5829613631        133794.0011        126156.101967394        7533.000076        10864.985777066
31        1300        23.9528320115737        28162.5        20968.5292170389        70125.00068        101053.998333236        6295.500062        22759.1078028146
32        1500        15.6992333063553        28741        17032.6273551743        98315.00096        70322.0662097171        38027.25039        44332.542010023
33        1725        10.2826732101151        15815        13689.1106086694        39736.00037        43621.8621594363        105129.0011        76574.1835737657
34        1705        6.73115178434093        10705        10861.3596690546        16287.75016        25319.8174389218        93082.50094        107981.69972014
35        2875        4.40427025702062        11208        8523.01656559652        9438.750095        14884.3521257475        110461.5011        114363.360488828
36        3100        2.880707990591        6354        6633.56709388255        8923.500089        9189.77798664163        95294.25096        88877.6175866567
 楼主| 发表于 2008-5-5 12:34 | 显示全部楼层
回复 3楼 的帖子
真的很感谢你
实在是不得已
所以才在论坛上请人帮忙
请问一下字符串长度大于1024这是什么意思?
我数据量太大也是一个原因吗?
所以才导致字符串长度大于1024
是这样吗?
感谢
GMT+8, 2025-7-2 11:56 , Processed in 0.065339 second(s), 19 queries , Gzip On.
