查看: 1362|回复: 0
[综合讨论] 求助 有关RTW编译中遇到的问题
发表于 2008-1-2 10:31 | 显示全部楼层 |阅读模式
我搭建了一个simulink模块,因为要做半实物仿真,所以要用 Tools|Real_Time Workshop|Build model进行模型编译,运行时出现了如下错误
Error building Real-Time Workshop target for block diagram 'k'. MATLAB error message:
Error using ==> callMakeHook.p>callMakeHook
The call to ti_c2000_ert_make_rtw_hook, during the before_tlc hook generated the following error:
    Error using ==> beforetlcHookpoint_tic2000target
This model does not contain any target preference blocks.
The build process will terminate as a result.
我是一个新手,对此摸不着头脑,请大虾帮我看看这个错误是什么意思,是如何造成的,谢谢!
GMT+8, 2025-11-21 12:52 , Processed in 0.055189 second(s), 17 queries , Gzip On.
