查看: 3261|回复: 5
[Fortran] [求助]关于fortran编写有限元程序的问题
发表于 2007-6-6 23:32 | 显示全部楼层 |阅读模式
大家好!在下是fortran语言的初学者,编写了一个有限元的程序,在执行compile时没有错误,但执行execute时显示两个错误,恳请各位前辈赐教!万分感谢!
显示的错误:--------------------Configuration: ll - Win32 Debug--------------------
Linking...
ll.obj : error LNK2001: unresolved external symbol _FJ@4
Debug/ll.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
ll.exe - 2 error(s), 0 warning(s)
原程序:
      program main
      common xy(200,2)
common/C/ie(200,3),ek(6,6),D(3,3),S(3,6)
common/C1/jf(20),fi(20),ib(80)
common/C2/zz(500,20),p(500)
      external in
call in(nc,ne,np,nb,nd,nj2,e0,pu,te)
call md(e0,pu)
      call cma(in,te)
call mzz(in,nj2,nd,ne,te)
call mf(np,nj2)
call mb(nb,nd)
call gau(nc,nj2,nd)
call sg(ne,te)
stop
      subroutine in(nc,ne,np,nb,nd,nj2,e0,pu,te)
common xy(200,2)
      open(1,file='in')
read(1,*)nc,ne,np,nb,nd
read(3,*)e0,pu,te
read(3,*)((xy(i,j),j=1,2),i=1,nc)
read(3,*)((ie(i,j),j=1,3),i=1,ne)
read(3,*)(jf(i),i=1,np)
read(3,*)(fi(i),i=1,np)
read(3,*)(ib(i),i=1,nb)
nj2=nc+nc
open(4,file='out',status='new')
write(4,*)nc,ne,np,nb,nd
return
      subroutine md(e0,pu)
d(1,1)=e0/(1.-pu*pu)
d(1,2)=e0*pu/(1.-pu*pu)
d(2,1)=d(1,2)
d(2,2)=d(1,1)
d(1,3)=0.
d(3,1)=0.
d(2,3)=0.
d(3,2)=0.
d(3,3)=e0/(1.+pu)/2.
return
subroutine cma(in,te)
common xy(200,2)/C/ie(200,3),ek(6,6),D(3,3),S(3,6)
dimension b(3,6)
im=ie(in,1)
je=ie(in,2)
me=ie(in,3)
cm=xy(je,1)-xy(im,1)
bm=xy(im,2)-xy(je,2)
cj=xy(im,1)-xy(me,1)
bj=xy(me,2)-xy(im,2)
ae=(bj*cm-bm*cj)/2
do 10 i=1,3
do 10 j=1,6
b(i,j)=0.
s(i,j)=0.
10    continue
      b(1,1)=-bj-bm
b(1,3)=bj
b(1,5)=bm
b(2,2)=-cj-cm
b(2,4)=cj
b(2,6)=cm
b(3,1)=b(2,2)
b(3,2)=b(1,1)
b(3,3)=b(2,4)
b(3,4)=b(1,3)
b(3,5)=b(2,6)
b(3,6)=b(1,5)
      do 20 i=1,3
do 20 j=1,6
b(i,j)=b(i,j)/ae/2
  20  continue
do 30 i=1,3
do 30 j=1,6
do 30 k=1,3
s(i,j)=s(i,j)+d(i,k)*b(k,j)
30   continue
do 40 i=1,6
do 40 j=1,6
ek(i,j)=0.
do 40 k=1,3
ek(i,j)=ek(i,j)+s(k,i)*b(k,j)*ae*te
40    continue
return
subroutine mzz(in,nj2,nd,ne,te)
common xy(200,2)
1     common/C2/zz(500,20),p(500)
do 10i=1,nj2
do 10j=1,nd
10    zz(i,j)=0.
do 20 in=1,ne
call cma(in,te)
do 20i=1,3
do 20ii=1,2
ih=2*(i-1)+ii
jh=2*(ie(in,i)-1)+ii
do 20j=1,3
      do 20jj=1,2
      il=2*(j-1)+jj
iz=2*(ie(in,j)-1)+jj
jl=iz-jh+1
if(jl.gt.0)zz(jh,jl)=zz(jh,jl)+ek(ih,il)
20    continue
return
subroutine mf(np,nj2)
common/C1/jf(20),fi(20),ib(80)/C2/zz(500,20),p(500)
do 10i=1,nj2
10    p(i)=0.
      if(np.gt.0)then
do 20i=1,np
j=jf(i)
20    p(j)=fj(i)
      end if
return
subroutine mb(nb,nd)
do 30i=1,nb
iz=ib(i)
zz(iz,1)=1.
do 10j=2,nd
10    zz(iz,j)=0.
      if(iz.gt.nd)then
jo=nd
else
jo=iz
end if
do 20j=2,jo
20    zz(iz-j+1,j)=0.
      p(iz)=0.
30    continue
      return
subroutine gau(nc,nj2,nd)
do 20 i=1,nj2-1
if(nj2.gt.i+nd-1)then
im=i+nd-1
else
im=nj2
end if
do 20k=i+1,im
il=k-i+1
c=zz(i,il)/zz(i,1)
do 10j=1,nd-il+1
m=j+k-i
10    zz(k,j)=zz(k,j)-c*zz(i,m)
      p(k)=p(k)-c*p(i)
20    continue
      p(nj2)=p(nj2)/zz(nj2,1)
do 40j=nj2-1,1,-1
if(nd.gt.nj2-j+1)then
jm=nj2-j+1
else
jm=nd
end if
do 30i=2,jm
ih=i+j-1
30    p(j)=p(j)-zz(j,i)*p(ih)
40    p(j)=p(j)/zz(j,1)
      write(4,101)
101   format(3X,3hjd=,5X,2hu=,16X,2hv=)
      do 50i=1,nc
write(4,102)i,p(i+i-1),p(i+i)
102   format(3x,I5,3X,f15.10,3X,f15.10)
50    continue
      return
subroutine sg(ne,te)
common/C/ie(200,3),ek(6,6),D(3,3),S(3,6)/C2/zz(500,20),p(500)
dimension wy(6),yl(6)
do 30 in=1,ne
call cma(in,te)
do 10 i=1,3
do 10 j=1,2
ih=2*(i-1)+j
jh=2*(ie(in,i)-1)+j
10    wy(ih)=p(jh)
      do 20 i=1,3
yl(i)=0.
do 20 j=1,6
20    yl(i)=yl(i)+s(i,j)*wy(j)
      s1=yl(1)
s2=yl(2)
s3=yl(3)
py=(s1+s2)/2.
ry=sqrt(((s1-s2)/2.)**2+s3**2)
sa=py+ry
si=py-ry
if(abs(s2-si).lt..001)then
set=0.
else
set=90.-57.29578*atan(s3/(s2-si))
end if
write(4,'(5X,"in=",i5)')in
write(4,'(2x,"sigmax=",f14.7,2x,"sigmay=",f14.7,2x,"tau=",f14.7)')
     & s1,s2,s3
      write(4,'(2x,"sigma1=",f14.7,2x,"sigma2=",f14.7,2x,"cet=",f14.7)')
     & sa,si,set
30   continue
      return
发表于 2007-6-7 12:39 | 显示全部楼层
   这句好像不可以吧:
发表于 2007-6-8 10:43 | 显示全部楼层
上面的common应该没有问题,估计是下面的子程序变量搞错了
  1. subroutine mf(np,nj2)
  2. common/C1/jf(20),fi(20),ib(80)/C2/zz(500,20),p(500)
  3. do 10i=1,nj2
  4. 10    p(i)=0.
  5.       if(np.gt.0)then
  6. do 20i=1,np
  7. j=jf(i)
  8. 20    p(j)=fj(i)
  9.       end if
  10. return
  11. end
其中
  1. 20    p(j)=fj(i)
应该是
  1. 20    p(j)=jf(i)
发表于 2007-6-8 21:51 | 显示全部楼层
变量名对应不上
 楼主| 发表于 2007-6-12 00:12 | 显示全部楼层
回复 #3 风花雪月 的帖子
真心感谢风花雪月前辈的关注与指导!按照您的指点我修改了一下程序,原来的那两个错误果真没有了,强呀,在下非常敬佩!程序现在能正常运行,但还不能得出正确的输出结果,估计是文件的连接的问题,我还需再思考一下。希望以后能再次得到前辈的帮助与指导!再次感谢!
发表于 2007-6-15 10:59 | 显示全部楼层
原帖由 追风少年 于 2007-6-12 00:12 发表
真心感谢风花雪月前辈的关注与指导!按照您的指点我修改了一下程序,原来的那两个错误果真没有了,强呀,在下非常敬佩!程序现在能正常运行,但还不能得出正确的输出结果,估计是文件的连接的问题,我还需再思考 ...
结果正确与否我就帮不了你了,这涉及到你这个程序具体的理论、你所给的模型、程序代码实现、你输入的参数等等一些列的正确与否
GMT+8, 2026-1-13 21:20 , Processed in 0.083807 second(s), 19 queries , Gzip On.
