查看: 4211|回复: 5
[C/C++] 粒子群优化PSO程序包
发表于 2006-10-22 16:14 | 显示全部楼层 |阅读模式
C语言程序包
This program is run under DOS environment.  To run it, under
DOS prompt, type in
        Pso  pso.run
then press the return key.
The pso.run file specifies all information required to run
the program. There are:
Number Of Agents
Minimum Error To Terminate running
Maximum Velocity
Maximum Range
Left Initialization Range
Right Initialization Range
Maximum Number of Generations for Each Run
Result File Name (Prefix)
Initial Inertia Weight
Function Type:
        0: Shaffer F6
        1: Sphere
        2: Rosenbrock
        3: Generalized Rastrigrin
        4: Generalizaed Grieank
Dimension of Function Selected
Number Of Runs For The Same Parameter Selection
Note: When either the error reaches Minimum Error To Terminate running or the current geenration
reahces the Maximum Number of Generations for Each Run, the program terminate its running.
Please contact Yuhui Shi at the address below if you have
any comments.
Yuhui Shi
Applied Specialist
EDS Indianapolis Technology Center
12400 N. Meridian St.
Carmel, IN 46032
yuhui.shi@eds.com
Phone: 1-317-705-6740
Fax  : 1-317-705-6710
http://www.engr.iupui.edu/~shi/pso.html
有需要的大家可以到下列地址下载http://www.pudn.com/downloads21/sourcecode/math/detail69745.html
发表于 2007-1-17 11:05 | 显示全部楼层
需要花钱的呀
 楼主| 发表于 2007-1-18 08:30 | 显示全部楼层
原帖由 qinle 于 2007-1-17 11:05 发表
需要花钱的呀
不用,你也可以通过上传其他资料后者程序来获取下载积分
附:并非广告,只是该站有很多源代码可供大家参考,所以推荐一下
发表于 2007-1-23 16:53 | 显示全部楼层
你去下了贴上来阿
 楼主| 发表于 2007-1-27 07:49 | 显示全部楼层
原帖由 qhust 于 2007-1-23 16:53 发表
现在论坛再不提供类似共享
发表于 2007-8-9 12:00 | 显示全部楼层
DOS prompt, type in
        Pso  pso.run
Number Of Agents
Maximum Velocity
Maximum Range
Function Type:
        0: Shaffer F6
        1: Sphere
        2: Rosenbrock
any comments.
Yuhui Shi
Applied Specialist
Carmel, IN 46032
yuhui.shi@eds.com
GMT+8, 2025-7-3 22:43 , Processed in 0.068413 second(s), 19 queries , Gzip On.
