查看: 3134|回复: 0
[Fortran] 利用窗函数法设计FIR滤波器
发表于 2006-8-8 07:19 | 显示全部楼层 |阅读模式
主程序一
  1. C----------------------------------------------------------------------
  2. c  main program H1DEFIR1: to test subroutine DEFIR1
  3. C  To design FIR low-pass filter by Fourier series method.
  4. c  Please link subroutine DEFIR1,FIRRES,AMPRES,PHARES,UNWRAP,WINDOW
  5. C----------------------------------------------------------------------
  6.         dimension b(0:20),w(0:20),amp(0:255),phase(0:255)
  7.         complex h(0:255)
  8.         data lb/20/,n/256/,iband/1/,iwindow/5/,iamp/0/
  9.         data fl/0.125/,fs/1.0/
  10.         call defir1(lb,iband,fl,fh,fs,iwindow,b,w,ierror)
  11.         write(*,*)'   ierror=',ierror
  12.         if(ierror.ne.0)stop
  13.         write(*,3)(k,b(k),k=0,lb)
  14. 3       format('                b(',i2,')=',f12.7)
  15.         call firres(b,lb,n,h)
  16.         call ampres(h,amp,n,fs,iamp)
  17.         call phares(h,phase,n,fs)
  18.         stop
  19.         end
主程序二:
  2. c  main program H4DEFIR1: to test subroutine DEFIR1
  3. C  To design FIR band-stop filter by Fourier series method.
  7.         complex h(0:255)
  8.         data fl/0.2/,fh/0.3/,fs/1.0/
  9.         data lb/20/,n/256/,IBAND/4/,IWindow/5/,iamp/0/
  18.         stop
  19.         end
子程序:
  1.       subroutine defir1(l,iband,fl,fh,fs,iwindow,b,w,ierror)
  2. c-----------------------------------------------------------------------
  3. C  Subroutine DEFIR1: To Design FIR Filter By Windowed Fourier Series.
  4. C  Fl:low cut-off frequency. Fh:high cut-off(For BP,BS). fl,fh,fs in Hz
  5. C  Digital filter coefficients are returned in b(l)
  6. c                H(z)=b(0)+b(1)z^(-1)+ ... +b(L)z^(-L)
  7. c  Input parameters:
  8. c   L+1  : the length of FIR filter. (L+1) must be odd .
  9. c   iband:  iband=1 low  pass FIR filter.
  10. c           iband=2 high pass FIR filter.
  11. c           iband=3 band pass FIR filter.
  12. c           iband=4 band stop FIR filter.
  13. c   fln,fhn: the edge frequency desired, in normalized form, 0.<=fln,fhn<=.5
  14. c          |---        |   ---       |   ---           |--      --
  15. c          |   |       |  |          |  |   |          |  |    |
  16. c          |   |       |  |          |  |   |          |  |    |
  17. c        --|------    -|--------    -|-----------    --|--------------
  18. c          0  fln      0  fln        0 fln  fhn        0  fln  fhn
  19. c             fhn=*       fhn=*
  20. c        iband=1 LP    iband=2 HP      iband=3 BP        iband=4 BS
  21. c  iwindow: window type desired.
  22. c           iwindow=1: rectangular window ,   =2: triangular window ,
  23. C                  =3: cosin window ,         =4: Hanning window ,
  24. C                  =5: Hamming window ,       =6: Blackman window ,
  25. c                  =7: Papoulis window .
  26. c        w: L dimensioned real work array.
  27. c  Output parameters:
  28. c   b: L+1 dimensioned real array.the result is in b(0) to b(L).
  29. C   ierror: ierror=0:      no errors detected
  30. C                 =1:      invalid length  (L<=0)
  31. C                 =2:      invalid window type
  32. C                 =3:      invalid filter type
  33. C                 =4:      invalid cut-off frequency
  34. c       From Ref. [5] in chapter 2 .
  35. c                                      in Chapter 8
  36. c-----------------------------------------------------------------------
  37.         dimension b(0:l),w(0:l)
  38.         pi=4.*atan(1.)
  39.         fln=fl/fs
  40.         fhn=fh/fs
  41.         do 1 i=0,l
  42.            b(i)=0.
  43. 1       continue
  44.         ierror=0
  45.         l=l+1
  46.         dly=float(l)/2.
  47.         lim=l/2
  48.         if(dly.eq.float(lim)) ierror=1
  49.         if(iwindow.lt.1.or.iwindow.gt.7) ierror=2
  50.         if(iband.lt.1.or.iband.gt.4) ierror=3
  51.         if(fln.le.0..or.fln.gt.0.5) ierror=4
  52.         if(iband.ge.3.and.fln.ge.fhn) ierror=4
  53.         if(iband.ge.3.and.fhn.ge.0.5) ierror=4
  54.         if(ierror.ne.0) return
  55.         dly=dly-.5
  56.         lim=lim-1
  57.         wc1=2.*pi*fln
  58.         if(iband.ge.3) wc2=2.*pi*fhn
  59.         call window(w,l,iwindow,ierron)
  60.         l=l-1
  61.         go TO (5,10,15,20) iband
  62. c----------- lowpass FIR filter design --------------------------------
  63. 5       continue
  64.         do 6 i=0,lim
  65.            s=i-dly
  66.            b(i)=((sin(wc1*s))/(pi*s))
  67.            b(i)=b(i)*w(i)
  68.            b(l-i)=b(i)
  69. 6       continue
  70.         b((l)/2)=wc1/pi
  71.         return
  72. c--------- highpass FIR filter design ---------------------------------
  73. 10      continue
  74.         do 11 i=0,lim
  75.            s=i-dly
  76.            b(i)=((sin(pi*s)-sin(wc1*s))/(pi*s))
  77.            b(i)=b(i)*w(i)
  78.            b(l-i)=b(i)
  79. 11      continue
  80.         b((l)/2)=1.-wc1/pi
  81.         return
  82. c-------- bandpass FIR filter design ----------------------------------
  83. 15      continue
  84.         do 16 i=0,lim
  85.            s=i-dly
  86.            b(i)=((sin(wc2*s)-sin(wc1*s))/(pi*s))
  87.            b(i)=b(i)*w(i)
  88.            b(l-i)=b(i)
  89. 16      continue
  90.         b((l)/2)=(wc2-wc1)/pi
  91.         return
  92. c-------- bandstop FIR filter design ----------------------------------
  93. 20      continue
  94.         do 21 i=0,lim
  95.            s=i-dly
  96.            b(i)=((sin(wc1*s)+sin(pi*s)-sin(wc2*s))/(pi*s))
  97.            b(i)=b(i)*w(i)
  98.            b(l-i)=b(i)
  99. 21      continue
  100.         b((l)/2)=(wc1+pi-wc2)/pi
  101.         return
  102.         end
GMT+8, 2025-7-5 00:41 , Processed in 0.070598 second(s), 18 queries , Gzip On.
