查看: 1970|回复: 2
[综合讨论] n*3矩阵用plot3画图后线很乱,如何处理
发表于 2014-8-4 12:59 | 显示全部楼层 |阅读模式
有一组n*3数据(每列为相应的x, y, z坐标) a.txt,
clear all;clc
load a.txt
plot3(a(:,1),a(:,2),a(:,3),'k-')
画出很乱的折线图(如图),要怎样画一条光滑的曲线,谢谢??
数据如下:
a=[
    2.338221983863957e-002   -5.256418590219274e-003    5.000000000000000e-002
    4.662703814441325e-002    7.371445839179751e-002    5.000000864565155e-002
    3.301435327171546e-002    2.745521807248888e-002    4.999999861837110e-002
    4.086588147578588e-002    5.412362614337204e-002    5.000000866100911e-002
    4.089677466773004e-002    5.196614500168657e-002    5.000000447124244e-002
    4.350255931525666e-002    4.798440631540006e-002    5.000000382191955e-002
    4.646288201131053e-002    4.891128473521992e-002    5.000000282769516e-002
    6.086842454745917e-002    5.935932464985707e-002    5.000000767795931e-002
    5.842169948045810e-002    6.483059987008050e-002    5.000000271977822e-002
    5.627989752313258e-002    7.406832679599720e-002    5.000000528904272e-002
    5.987434359571897e-002    7.710675508524252e-002    5.000000314591277e-002
    6.619882002147375e-002    8.620828357548525e-002    5.000000493360141e-002
    6.369567969565480e-002    9.180468488046806e-002    5.000000371696105e-002
    6.205892122797832e-002    1.020650906895091e-001    5.000000465775030e-002
    6.459395488806974e-002    1.077462752053967e-001    5.000000368097513e-002
    6.433898934308704e-002    1.173919972408321e-001    5.000000413984021e-002
    6.114056350154880e-002    1.252108914953766e-001    5.000000416375358e-002
    6.183558112173672e-002    1.347439204897166e-001    5.000000432497839e-002
    6.326606995534122e-002    1.437924954691107e-001    5.000000420509337e-002
    6.247286936020523e-002    1.540139588544642e-001    5.000000415229455e-002
    6.295490273309780e-002    1.632759785079671e-001    5.000000420209538e-002
    6.368142849351088e-002    1.744882355712298e-001    5.000000422494365e-002
    6.395088682641653e-002    1.840416831506874e-001    5.000000411363113e-002
    6.487714440235795e-002    1.958420091054539e-001    5.000000431672367e-002
    6.551738058062526e-002    2.053629928428032e-001    5.000000408332753e-002
    6.644508263376169e-002    2.163868857819573e-001    5.000000433739920e-002
    6.714469409449875e-002    2.248744801413686e-001    5.000000406741445e-002
    6.802201502683486e-002    2.347360481495560e-001    5.000000429260068e-002
    6.861395734376745e-002    2.423026833787667e-001    5.000000391448495e-002
    6.935329279937656e-002    2.510991175665099e-001    5.000000439042276e-002
    6.979891986669480e-002    2.578597583279395e-001    5.000000410710509e-002
    7.033369863549893e-002    2.657204494736932e-001    5.000000416078314e-002
    7.065488527897580e-002    2.717896366961513e-001    5.000000411134038e-002
    7.099726004686439e-002    2.788120418143846e-001    5.000000425541953e-002
    7.126913244588212e-002    2.842739390135971e-001    5.000000411352835e-002
    7.170115849945105e-002    2.905687464862775e-001    5.000000424276790e-002
    7.228209651301065e-002    2.954388830724494e-001    5.000000425765715e-002
    7.325271695704605e-002    3.011769184996905e-001    5.000000411233726e-002
    7.424141271223872e-002    3.053622093782033e-001    5.000000423777067e-002
    7.563822699472621e-002    3.104431242270999e-001    5.000000417854583e-002
    7.670295828639813e-002    3.139627522151042e-001    5.000000427691492e-002
    7.808887558056836e-002    3.184388316866029e-001    5.000000419238628e-002
    7.901640040622956e-002    3.213336121573095e-001    5.000000440619440e-002
    8.027739051625146e-002    3.251621091637674e-001    5.000000461269826e-002
    8.106611144922667e-002    3.274143112317574e-001    5.000000503313613e-002
    8.229923013240580e-002    3.307846080188908e-001    5.000000615223756e-002
    8.286894823401282e-002    3.322106885757585e-001    5.000000667854810e-002
    8.403857701651195e-002    3.350943561000025e-001    5.000000749321945e-002
发表于 2014-8-6 14:44 | 显示全部楼层
 楼主| 发表于 2014-8-7 16:35 | 显示全部楼层
chybeyond 发表于 2014-8-6 14:44
参考下这个方法:http://blog.csdn.net/yihandk666/article/details/7109817
谢谢指点
GMT+8, 2025-7-23 22:34 , Processed in 0.076746 second(s), 23 queries , Gzip On.
