查看: 1421|回复: 0
[编程技巧] 【分享】不相交的随机大小的椭圆
发表于 2012-9-11 09:23 | 显示全部楼层 |阅读模式
此函数产生的椭圆通过调整长径比可以用来模拟纤维混凝土中的纤维,当然也可以模拟类似的其它材料。
  1. function myellipse
  2. % cheng wf 2007 6 11 19:51
  3. close all
  4. clear all
  5. clc
  6. %format compact
  7. depth=60;
  8. a=[3 2 1 0.5];b=[2 1 0.5 0.25];
  9. number=[10 10 100 20];
  10. x0=[];y0=[];xlat=[];ylon=[];
  11. [x0new1,y0new1,xlat1,ylon1]=myellipse_one(depth,a(1),b(1),number(1),x0,y0,xlat,ylon)
  12. x0=x0new1;y0=y0new1;xlat=xlat1;ylon=ylon1;
  13. for i=2:length(a)
  14.     [x0new2,y0new2,xlat2,ylon2]=myellipse_rest(depth,a(i),b(i),number(i),x0,y0,xlat,ylon)
  15.     x0=x0new2;y0=y0new2;xlat=xlat2;ylon=ylon2;
  16. end
  17. %  绘制椭圆图形
  18. [m,n]=size(xlat)
  19.     plot(xlat,ylon)
  20.     axis([0 60 0 60])
  1. function [x0new,y0new,xlat,ylon]=myellipse_one(depth,a,b,number,x0,y0,xlat,ylon)
  2. xxlen=length(x0);yylen=length(y0);
  3. x0(xxlen+1)=a+(depth-2*a)*rand;
  4. y0(yylen+1)=a+(depth-2*a)*rand;
  5. ecc=axes2ecc(a,b);
  6. [lat1,lon1]=ellipse1(x0(xxlen+1),y0(yylen+1),[a,ecc],rand*180);
  7. xlat=[xlat,lat1];ylon=[ylon,lon1];
  8. for i=2:number
  9.     while 1
  10.     x0(xxlen+i)=a+(depth-2*a)*rand;
  11.     y0(yylen+i)=a+(depth-2*a)*rand;
  12.     [lati,loni]=ellipse1(x0(xxlen+i),y0(yylen+i),[a,ecc],rand*180);
  13.     xlat=[xlat,lati];ylon=[ylon,loni];
  14.     for j=1:xxlen+i-1
  15.         in1=[];in2=[];
  16.         in1=inpolygon(xlat(:,xxlen+i),ylon(:,yylen+i),xlat(:,j),ylon(:,j))
  17.         in2=inpolygon(xlat(:,j),ylon(:,j),xlat(:,xxlen+i),ylon(:,yylen+i))
  18.         if all(in1==0)&&all(in2==0)
  19.             n_j=j;
  20.             if n_j==xxlen+i-1
  21.                N=1
  22.                 break
  23.             end
  24.             continue
  25.         else
  26.               N=2;
  27.               xlat(:,xxlen+i)=[];ylon(:,xxlen+i)=[];x0(xxlen+i)=[];y0(yylen+i)=[];
  28.               break
  29.          end
  30.      end
  31.       if N==1
  32.         break
  33.       end
  34.    end
  35. end
  36. x0new=x0;y0new=y0;xlat=xlat;ylon=ylon;
  1. function [x0new,y0new,xlat,ylon]=myellipse_rest(depth,a,b,number,x0,y0,xlat,ylon)
  3. ecc=axes2ecc(a,b);N=0;
  4. for i=1:number
  5.      while 1
  6.     x0(xxlen+i)=a+(depth-2*a)*rand;
  7.     y0(xxlen+i)=a+(depth-2*a)*rand;
  8.     [lat,lon]=ellipse1(x0(xxlen+i),y0(xxlen+i),[a,ecc],rand*180);
  9.    xlat=[xlat,lat];ylon=[ylon,lon];
  10.     for j=1:xxlen+i-1
  11.         in1=[];in2=[];
  12.         in1=inpolygon(xlat(:,xxlen+i),ylon(:,xxlen+i),xlat(:,j),ylon(:,j));
  13.         in2=inpolygon(xlat(:,j),ylon(:,j),xlat(:,xxlen+i),ylon(:,yylen+i));
  14.         if all(in1==0)&&all(in2==0)
  15.              n_j=j;
  16.              if n_j==xxlen+i-1
  17.                 N=1;
  18.                 break
  19.             end
  20.            continue
  21.        else
  22.              N=2;
  23.              xlat(:,xxlen+i)=[];ylon(:,xxlen+i)=[];x0(xxlen+i)=[];y0(yylen+i)=[];
  24.               break
  25.        end
  26.     end
  27.        if N==1
  28.        break
  29.        end
  30.   end
  31. end
  32. x0new=x0;y0new=y0;xlat=xlat;ylon=ylon;
GMT+8, 2025-7-26 07:16 , Processed in 0.069464 second(s), 19 queries , Gzip On.
